Tire Glue
i don't race but i do know you don't have to go out and buy "special tire glue" CA GLUE as its called works just as well and you can grab it at your hardware store...
I use zapagap and GP CA. never had a issue Also if you glue the bead 100% it will be fine. if you do the edge like most hobby shops do it for you, they will let go ....
I used AKA Premium Tire Glue. Don't have much to compare it to, but I got great results from it. There is enough in the .70 oz. bottle to do several sets of tires, and I have the Tremor wheels which probably used a bit more glue with the larger outer diameter.
don't use super Glue!
ive tryed it..
I'm with bank on this one..
as i said as long as its CA glue you ok,the stuff i've used here is just general purpose glue as well but was called superglue or something close to that lol and it was just CA glue seemed to work ok
