Brushlessboy16
If you haven't seen already, parts have been donated from HPISF members through ThePopeNJ for this build thank you HPISF 🙂
Made my motor mount, Its very sturdy but I need to brace the motor plate length wise as it flexes...
Mounted my wing on the wing mount, ready for everything else. I get the things tommorow!
SOOO. finally
ARound 11 alex dropped off the parts for my truck. come to find out he left the transmission home, so no motor mount or anything.
Then sifting through the parts, i found that it didn't have any suspension hinge pins... So Try and find substitutes, wait and get them or make my own.. So i went down to the local hardware store and picked up 5/32 hardened steel rod. and made ALL my hinges with it.
I went through and installed the front and rear assemblies with the hex head hardware i got, installed skids and bumpers, made outer hinge pins, installed shocks, and started to put together my radio box.
I still need bearings for the steering bellcrank assembly, the upright posts for the belcrank and 2 toe links for the rear suspension.
Another Big up date. scavenging around the shop today i was trying to figure out a way get the steering installed.. My main problem was finding bearings to fit in the steering assembly. The answer came in the form of bearings from an old transmission out of an electric duratrax evader... Next came the steering posts. Found a great match with Center differential mounting posts from an ofna Hyper 7 which i had lying in the junk box.. One end was drilled for m3, and one end was larger with an m4 opening. Hacked off the large end and it made perfect steering posts, they bolted into the stock location and work great.
Then i just had to dry fit the wheel tires and body!!
