Seems like many use the Losi Zombie/1/2" Offset Maximizer Beadlock combo and have problems with the tires ballooning or distorting, so after i saw a post by the judge, i decided to try the pro line foams & duct tape. Never used the tape before so if i didn't do it right, please feel free to correct me:
I started with:
Losi Zombie-Maxx tires Part # LOSA767 OR $30.39 x 2
Maximizer 1/2" off set beadlocks # MAX1731 $27.99 x 2
Pro line foams part # 6198-01 $8.99 x 2
1 roll of Gorilla tape that i already had
On first attempt, i tried to install the yellow foams that came with Zombies, but became extremely frustrated as they distorted the shape of the tire. After seeing a post by the judge with the part #, i trucked on down to the LHS & picked them up. Notice how they are shaped like the tire itself & how different it is from the foam supplied with the tires. They claim that the foam has a longer life expectancy than the yellow foam & it has more of a 'dead' feeling instead of a 'springy' feeling.
Next I turned the tire inside out as instructed from one of my hpisf bros
then i wrapped some gorilla tape around the tire (not the side wall, just the tread area) which is the same width as the tape (2") so no cutting of the tape was required
Then i turned the tire back to its original position (which was easy because the inside of the tire is extremely tacky & the tape sticks like crazy) inserted the foam and proceeded to mount it on the Maximizer bead lock. Here is a pic of the tire with the tape & pro line foam installed. Notice the nice uniform shape of the tire with no cutting of the foam required
and there is a good video of how to mount the tire on the maximizer beadlock which is located here: http://www.maximizerproducts.com/instructional-v.cfm
unfortunately i haven't had the chance to run my truck with the new skins just yet because it is still in pieces, but hopefully i will get the chance this weekend and report my findings.
Please comment on my tire build...freddy
I started with:
