slamgilbert
Looking to change to 24mm hex so that I can run the low profile tires like the HPI 1/5 scale tires. Would like a way to to get a wider stance, thru tires or hex hub's also. Does anyone have any thoughts on that?
wider stance? go with 1/2 " off set wheelsLooking to change to 24mm hex so that I can run the low profile tires like the HPI 1/5 scale tires. Would like a way to to get a wider stance, thru tires or hex hub's also. Does anyone have any thoughts on that?
i saw that bro that thing looks sick,can you post part numbers and wheel and tire combosGo for it!
I XL'd my flux & put the 24mm hubs with baja wheels.
yes it does ,thanks a million .alohaCheers! Heres what I'm running
Hub kit
Wheels & Tyres
But I changed the Tyres to these
Much better
Hope this helps
