romper4444
Anyone know if the XL 17mm wide axles are a direct bolt on to the x versions? The diameter seems to be the same, just a longer shank with a collar in between the bearing and axle pin/hex. Seems like the easiest/cheapest way to widen the X? Just thought I'd ask is anyone's tried it before I drop some cash, Thanks guys! Hpi # is 86249, axles are still 8X11mm, but 56mm in length instead of 44mm??
