mess1ah1
So that steel insert in the vorza cup isn't molded into the cup?
That bearing blowing out is still an issue for my with my savage's. I just try to keep an eye on it. Any idea of the savage internals fit inside that cup?
No clue why HPI went the route they did. I wonder if turning down the aluminum cup will be a good idea. Will make that output boss pretty thin and likely to crack.
Guessing the forsa one is sintered steel or machined steel whereas the other one appears to be cast aluminum. So, may be likely to crack on you.
Hope the modded HPI diff case is as strong as the Vorza diff, is the Vorza diff insert made from steel vs the aluminium HPI diff?
What are those upper arms connected to? Looks way different to the usual setup? That area where this thingo goes View attachment 7980
Putting the LiPo's in the front under the cage thing?Some updates. FLM motor plate moved back about 1 1/2” from stock location and will be where the esc gets mounted. Nice and low. I’m using a Vorza radio box, mounted on the Hellfire towers. Everything is going to be between the TVPs. (I never liked having the bulky, ugly battery boxes hanging off the outside of the TVPs like some stupid saddle bags. Looks slapped together and just terrible in my opinion.)
View attachment 8266View attachment 8267View attachment 8268
