"Will these work in my sts .28?"
Samrsnow
AKA glue sniffer
Metairie Louisiana
Hey guys I've been looking for some boca bearings for my sts .28
I found these... http://www.bocabearings.com/main1.aspx?p=product&id=7108&n=*ENK-161HP it says they work on the sts .21 through .31 engines but i just wanted to ask and make sure i'm buying the right ones because they don't say what size they are!! :stickspank:
Oh and the bearing sizes for the sts .28 are:
front bearing is 7mm-19mm-6mm
main bearing is 14mm-25mm-6mm
Thanks in advance.
If you click on the part # it will take you to the individual bearing. Those are the right ones, they will work just fine.
Sam, why spend $40 for bearings on a $110 engine? I would just run the stockers. They may hold up longer than the engine. Also, if you don't know what your doing, you can damage the case when changing them.
