Will a Hellfire body fit on a savage
racerguy_14
grangeville, Idaho
I'v been looking for cool bodies for my 4.6 and i was just wondering if a hellfire body would fit on a savage. and if you would have to make any huge modifications to get it to fit.
i've got a savage 4.6, basically stock with a 3-speed and rcraven roll cage
david
I guess its trial and error unless someone here has done it,i have a hot bodies stadium truck and the body is very similar in size to the hellfire and size wise it will fit with a few mods,if you know anyone with a hellfire you could borrow the shell and measure it up but with so many nice shells out for the savage,is it worth it?????
w00t
Just look up the dimensions of the body you want, and compare those to the dimensions of the stock body and you should have your answer. Pretty much any body can be modified to fit as long as the dimensions are right.
Jt
WNY
The body wil fit might need to remove the roll bar so the body doesn't sit so high but it can be done with a little work.
carldav
AUS
Yes, Hellfire body fits well on my Savage XL:
