Why would this keep happening?
sfrayser
I keep blowing my left front tire off. I have glued it like 3 times. Granted I'm running a Castle Mamba 2 on 6 cell. Any ideas on how to keep it on other than stay out of the throttle?
Clean both tire bead and wheel beads with denatured alcohol and glue it down again and this time let it set a couple days so your glue can dry well.....
Maybe even swap that tire to the rear so it doesnt get all that freewheeling rpm..... and as always when the tires are not on the ground then letting off will also help not throw tires off the rims.....
Also, use some fine sand paper to rough up the surface on the wheel and on the tire bead after cleaning with DA.
Could also increase the oil weight in your front diff so more power is transferred to the tire on the ground which will pull the truck forward and hopefully pull the other tired down with it.
yes, olds is right, I run 50,000 weight oil front and rear and have another diff with 100,000 weight , you might run 100,000, sounds like you need it,
