n2opony92
- Covina, CA.
Sorry, newb here.. but whats the advantage in upgrading?
upgrade to digital 2.4Ghz
1. no more crystals or interferance with other peeps Tx.
2. built in fail safe.
3. longer range (you can run your truck appx 3x father away from you)
4. faster data transfer (ie your truck will respond faster to your control input)
5. adjustability (ie. set servo endpoints, abs braking capability, throttle/steering response adj)
6. ability to control multiple models/r/c's using only 1 Tx.
7. eliminates the long antenna on your Tx & your Rx.
