wheels
savage_ricky
uk
i am having trouble under standing wot measurements meaning are to the locashion to the wheel i have tried looking and couldn't find any thing
I.E
Outside Diameter:
Inside Diameter:
Width:
Inside diameter is a measurement that only applies to tires. It should match the outside diameter of the wheel it's mounted on.
The Savage (like most monster trucks that I know of) uses wheels with an outside diameter of 3.8 inches.
Not entirely correct, early Savage models used a wheel with an outer diameter of 3.2 inches
Newer ones do use a 3.8 with a 17mm hex drive wheel
420 series are also a 3.8 wheel but utilize a low profile tire...
If you buy mounted tires and wheels look for a tread pattern you like and wheel style you like and post up a link we can help you decide which is correct for your rig......
