Wheel Extensions or Extended arms?
fluxhappens
Which one should i go for, the wheel extensions will cost 30 bucks, the extended arms run 150 unless someone else besides flm makes them? Any one have either and are you happy with your choice?
Thanks?
My buddy got the wheel extensions and loves them.. and paid around $32 or so.. i guess it's just matter of prefference.. I"m sure someone will jump in soon with more info.. JMO..
I agree with frddyj, no doubt the easier and cost effective way to gain better stability. Dual offset wheels are a simple easy way to adjust a trucks wheel offsets with no major changes. Then you can see if you really need to spend big bux and time involved with changing parts. In our experience naaa. Just flip the wheel and your set. Plus you can differ the offset wide on the rear and narrow on the front similar to different tire treads front and rear ( Like Bow-Fighters), plus a multitude of other offset choices. This is why they were designed, to minimize the cost of 2 sets of wheels/tires and minimize the cost and effort in switching suspension parts. These wheels also offer track side tuning, what does it take to flip a wheel? Not much, So I Double up with frddyj on his recommendation. Can't wait for Memorial Day Weekend we are gearing up for another great race experience!!!
Hold on to your seats our R&D Dept. is working on a real cool simple cost easy upgrade that will rock your boat. Or truck in this case. See Y'all at the W/F 2010
i have to agree with the offset wheels. if you do decide to run the blue grooves above you have to use there 17mm adaptors or they wont cover the warrenty on them and you will strip hexes out. the plastic adaptors that come with the blue groove wheels don't fit a savage. but if you use the adaptor they are awesome wheels
any recommendations on a good set of offset rims, since everyone seems to lean towards them ove the arms or extensions? Would beadlocks be good to go with or is flux power to much? I had them with my summit and they are alot easier to deal with than glue?
