Whats on your Savage Wishlist?
ShiftPoint
Ft. Laduredale, FL
I hope this is the right place for this.
I don't know if this has been done yet, but I thought it would be cool to see what kind of upgrades your wanting. and maybe add to our lists from each others.
What are the items you have been wanting for your Savy that for whatever reason you haven't bought yet.
Here's my list, mostly cause I can't affprd them or haven't been able to justify the price but would like to have. Post links if you like. (worse cause I have 2 trucks)
these arent really in any order
allso update your list as things come out your wanting
1. cerimac Bearings
2. high powered servos (the 333 to 400oz suckers)
3. New mills, I would like a LRP and a TM928
4. Nova coolng head
5. X version alloy diff case's (nobody makes them yet, that I know of)
6. set of shocks for 1 of my savys (will be taken care of when the big bore's come)
7. TVP's I would like to try the TI ones from Hardcore racing
8. I would like to try a set of the new Imex rubicon tires
https://www.hpisavageforum.com/forums/showthread.php?t=4643
9,. another Buku for my other truck
10. Baja bug body, and a couple others in time.
Beleive it or not that's all I can think of right now. all huh 🙂
wishlist, mmmmmmmmm
ok
1. Vantage a arms
2. Vantage pipe
3. carbon tvp's ?
4. 3 speed transmision w/upgraded gear ratio
5. good digital radio gear ?
6. servo's ?
7. maximizer bead locks
8. crimefighters
9. BIG BORE HPI SCHOCKS
10. professionally modded .32
I have to do some research on the rest, RC parts are alot like candy you want it all . but, you know you be sick if you do. lol
1. Buku Big Block Pipe
2. HPI Big Bore Shocks
3. 1/2 Offset Maximizer Bead Locks
4. Low-Profile Off-Road Tires (Nubz,Crimefighters,Dirtbonz)
5. Steering Servo that wont bonk
6. Associated LRP Z .28R Spec 3 engine Polished/Ported
7. Spektrum or Futaba Digital Radio Gear
8. Heavy Duty Hex Screw Set
9. Heavy Duty Aluminum Steering Bulkheads/Axle Carriers
10. HD Dogbones/CVD's and 23mm Conversion.
What he said in that order -5 and 6. Already got a servo.
my 5 and 6.
5. New body, Cuda or Maximum Destruction (If they have it somewhere)
6. Fuel Tank, Radio Box, and skid plates.
hmm ... this is tough!!
1. 2.4Ghz Radio System
2. Buku Pipe
3. dual brake setup
4. hofna link upgrade
5. faster & more powerful steering servo
6. better looking bodyshell
7. LRP engine
el camino shell
3 speed tranny
buka pipe
tires that arnt tore up
thats all .
ive done vantage a arms, tuned hpi pipe, beadlock rims, monster tieres
645 sterring servo 590 throttle,spectrum remote
this is a good thread:$broke:
lrp mill
3 speed trans
digital radio and servos
new driveshafts
more rims and tires?
everything else they make for the savage
OK here is mine.
Hump Back
Nova Cooling Head
Nova Clutches
Big Joes with Maximer beadlocks
Hex Head Screw Kit
New brakes
thicker motor plate that wont bend
My big ones are:
250cc fuel tank
Buku Pipe
Pro-Line White Pre-Mounted Crime Fighter MTR Half Offset Monster Truck Tires
And the most important thing on my wish list is to finish my Brushless savage.
My big ones are:
250cc fuel tank
Buku Pipe
do you have a link to the 250cc tank? does it have to be fitted in the center. Wish I could do without the reverse , I would do the center tank mod.
Yeah it's fitted in the centre. You could probably do the mid tank mod and use a micro servo for reverse. Something like a HS81 would be strong enough to operate the reverse module and still fit up the front. Even full sized servo mounted on the left opposite the steering servo would probably work as well.
Thanks Tim.
hmmmm my wishlist.....
alum bulkheads
flm tvp's
irc shock conversion
bigger fuel tank
new radio -spektrum or something comparable
hpi 5.9 engine when and if they come out lol
lets see.....
rpm radio box
250cc mid tank mod
lrp spec3
upgraded steering servo
3 speed trans (with or w/out reverse)
got the flm tvp's and a new futaba tx and rx.
still want the rest of the stuff.
