What tank mod is for me?
gnarkill
I want to do a mid tank mod but I have some concerns. I see that most people use a FLM extended tvps, but I would rather do it on the stock savage x 4.6 tvps. Also, I notice many people use generally small tanks. What is a decent size tank (200cc-ish) that I could use without putting my receiver on the side of my tvp.
-Thanks for your time.
What is a decent size tank (200cc-ish) that I could use without putting my servo on the side of my tvp.
Hey bro, not sure if your refering to the steer or t/b servo being relocated, but here are some thoughts:
1. you can def do a mid tank on stock x tvps
2. you can def do a mid tank w/o moving the steer servo.
3. i don't see how you could do a mid tank without moving the t/b servo caz you need to make room for the tank.
a few peeps have done mid tanks using a Hellfire 150cc tank, the correct Platinum r/c plate and moving the t/b servo to stock tank location.
Sorry guys, I meant to say put the Rx on the size of the tvp. I wrote this at 5:30 in the morning so I was alittle tired.
hey bud the guys are right
The throttle servo has to move in order to make room for the tank.
To get an 200cc ish tank you will have to move the steering servo either under the servo plate or side of the tvp's
If 150cc is cool with you go with the hellfire tank like frddy mentioned
Not too many stock tvp midtanks that I know of, but here are a few
-Tank is only about 125cc's though 🙁
My 25 budget mid tank
-this one should be closer to your x tvp's
Mickey's xl midtank
- this one shows a couple of bank's x tvp's throttle mount and top view of new tank.
Banks x
- here are a couple more x tvp's
ryanpretty's x
Just a couple of links, I'm suer you could find more if you have a few hours to look through the mid tanks section
Good luck and post lots of pics!
Mickey's xl midtank
Banks x
ryanpretty's x
gnar you can pm me for info on my xl midtank i used a 125cc ofna tank but there is room for larger tanks
The mid-tank mod is over-rated and pain in the ..... IMO.
You have to move a bunch of stuff around, you get a small tank that gets fuel and dirt all over your servo and it looks stupid.
Again, just my opinion.
Finally someone who understands!
ok, lol, this changes my answer a bit. if you change to ext flm tvps, you will increase the choice of mounting options for your Rx.
Members Baddasz_Savage and The Pope NJ have mounted their Rx pack behind the mill (able to do so because of the 1.5" extension on the flm tvps) and they were very happy with it.
Megabyteme mounted the Rx inside the tvp and under the mid-tank plate on the forum truck which was the prize for the WF long jump 09; you might be able to accomplish something like this with stocker tvps also.
lmk if you want me to dig out the links 4 you.
I somewhat agree with that but are there other ways to fix mid tank lean with out sacrificing the tank size because that is all I am really trying to accomplish.
I run a 125cc Ofna tank in the stock location, and it works fine for bashing. You get used to re-fueling more often, most of the time when I pull the truck in to re-fuel the tank is still 1/4 full or so. It is also the only setup that positions the tank out of the reach of the upper shock bolts.
I used to run a mid tank setup, but after the front shock tower smashed 2 tanks, I went back to the stock position. Some claim that a mid tank improves the handling of the truck, and I thought so too, until I went back to the stock position and realized that it was only the placebo effect.
Almost everything you do to mod your savage is going to have a + and a -. You just have to weigh it out and make that choice for yourself but no matter what it is very few of them are cheep and easy. There is a good amount of wrench time to be put in on these trucks no matter what it is you do with them unless of course you just want a shelf queen.
I run a larger and longer fuel lines through the shock tower and down the back of the Savage. This eliminated my half tank lean.
This mod seems to work for about 50% of the people trying it. Can't pin point why it works for some and not for others though. But it only cost a few cents to try it.
Using longer lines worked for me somewhat but did not completely eliminate HTL. I want to do the PRC mid tank mod for the OFNA 250cc tank. It will be a pain the mount my T/B servo on my stock XL TVP's but I think it will be worth it just for the extra fuel capacity not to mention getting rid of HTL. And the I'll be set up later for when I want to invest in new TVP's, either FLM or PRC.
