NITRONUT
- Lindenhurst N.Y.
so different amounts of fuel burn at different temps?
Absolutely they do.
The temp of the burning fuel/air charge will vary because of the amount of oxygen in the charge.
That is why your engine will run hotter when its lean than when its rich. The best way to look at it is like this.
First thing you have to remember is your engine can only draw a certain amount of fuel and air into the combustion chamber. This is set by a whole host of things like the # of ports, port timing, crank timing and so forth but that isn't important right now.
Now with that said, if you have more fuel going into the combustion that will leave less room for air making the fuel burn slower and not as hot, hence a cooler running engine making less power.
If you have less fuel going into the combustion chamber that will leave more room for air and will make the fuel burn faster and hotter, hence a hotter running engine making more power.
I hope this answers your question.
