what if i like 4 fat shocks??????
36chambers
what should i get????anwsers and comments...pics even better!!!!piccogirl
They don't come much fatter than LST shocks
Or theres HPI Big Bores
HPI big bore next to a stock shock.
The LST's will add a bit of extra weight to your truck with the mounting kits and what not.
The HPI big bores are a direct bolt and not a huge weight difference over stock shocks.
From my experience with LST shocks. The IRC mounting kit is top notch. I would recommend Aluminum shock caps and the shock shafts are a little on the brittle side.
left to right - stock savage shock, HPI Big Bore, LST XXL
picture.php
Ran the hpi threaded shocks till I got the RSC than I had to switch to big bores. I liked them well enough though.
Y'all heard of powerline big bores. ??? I think I found set
You can get the plastic BBs for less than $57, more like $45 or so online I think.
Pretty sure most people on here think they are fine.
looking on the boards i see everyone has the silver shock mounts flipped upside down???are those i posted a pic of look like its mounted correctly??
so do the back shocks go closer to the motor ..or behind the rear diff???seen them on both ways??
on there way 54 bucks on ebay...:) what oil should i run in them???
That price for the shocks and mounting kit? Bargain!
Welcome!
By the way, depending how hard you like to bash... you might want to get some spare shock shafts... heard the LSTs are a little week
