What Brakes Should I Get??
SAVDOG
What Brakes Should I Get? Give Me Some Insight On What You Think I Should Get For My Brake Setup.
Thanks.
yep i've got a set of the red fiber dual disk brakes ordered myself!! i have talked to alot about it and most say there awsome!!
I thought I would mention. I am using the FLM LCG chassis plates and these brakes are only just above the bottom of the TVP. There is no protection unless you run the bash plate (I do). I haven't actually tested it yet but I would recommend bash guard on any chassis not just the FLM's.
I use duel Vertigo Performance CF disks. They work amazing with the stock brake calipers.
I use the HPI Dual SS brakes and have been exceptionally satified with them!
The pads supplied with them appear to be the same material that the 4.6 discs are made of.
