Weird brake fade problem
SDMorris
Look whos back!
Hey guys. So here is my problem. I have an X4.6 with the red fibre brakes, and the ofna throttle mod. Every time I turn my truck on, my brakes are working awesome, like so good that if I hit them all the way it does a frontflip. About 4 minutes through the tank they start fading, and eventually get to nothing. Every time, I pull the truck up, look at the linkage, and brakes, and everything seems to be functioning fine EXCEPT the brake pads, they stop moving. Turn it off, come back next day, they are working great again. Any suggestions?
bake fade its getting to hot try losening up the brakes you don't need the brakes to make you do a endo wich tells me you got to much brake wich is causing to much frition which leads to heat wich is bad
Yup ditto, if you can endo you got too much left pedal. Back off your EPA on transmitter and that problem will fade away!
