Doginjeep
This is going to be a long and specific question(s). I've looked through lots of old tuning posts so please don't hate on me for this.
1) I'm running a used Axial .28 spec 1S. Rotor-start. It has great compression. The seller ran it for me. The needle settings were left alone until I couldn't start it myself. Good plug and igniter.
2) it's mid-winter. Outside temp is about 4deg C.
3) new tank and lines.
4) I have the trim on the tx set properly.
So I set all the needles back to flush and went at it. Finally got it idling with a leaned out LSN and ultra-rich Hsn. The MSN is set flush and the gap is set at the 1mm standard. The idle speed is so high that the clutch strts pulling but not crazy hard. With this tuning the thing wouldn't get any speed, so as I ran it around and got the temps up, I started to lean it out. Finally I have this truck pulling fast enough to make it into second gear and checked the temp to be 235F. I am new to this and don't want to burn out this motor. (If anybody knows what I've been through I can tell you this is my 2nd used savvy. Now I have one with no running motor. )
Anyhow, after tuning to get it running strong and making about eight high speed passes, I realize I burned through a tank of fuel and had to gas-up.(I'm sure having the big heavy tires on it doesn't make it easier) I couldn't get it started again! I noticed that the fuel Line was not staying pressurized, hence no fuel making it into the carb. Had to go rich on the HSN to get it running again and then lean it out to get performance. I don't want to do this every time . This is supposed to be fun.
Questions
1) is this problem because of the cold outside temp? And is it just normal procedure?
2) how much run time should one expect out o the 160cc tank? I've gone through about six tanks trying to tune it. I'm using the traxxas 30% fuel which is what the org.owner broke the motor in on.
3) I really would like to get the idle dialed in so that it doesn't pull.
Questions
