RangerRock
Hey guys I have problem with the tranny. Megabyteme it worked fine for for 1 Tank and then when it vut off I went to restart it and it is already engaged, as starting in gear. I tore it down to check the gears and the gears are fine. When I roll it fowards in F it is fine but when you roll it backwards the tires lock up......that's while holding the spur gear. Also on the spure gears by the slipper pad their is a little desigh almost like a square and it knocked those off. Please help as I want to get to break-in my STS. Cheers
