tranny case
devoejl
is there an aluminum or hardened tranny case for the savage x i just got this toy used and the screws are stripped or stripping in the top cover?
There is aluminum cases but they are of the old design, I haven't seen any of the X style yet.
The best thing to do is get a new case. How bad is it stripped?
bad the top 2 screws don't do much the rest are not bad
Really not an easy fix, especially when it is the top screws of the X case. I would go get a new case that has the 3 screws on the top (revised version for the X SS)
You can use glue but in this case when there is so little thread and that is the part of the case responsible for keeping gear mesh...not sure if I would trust it to hold it. If doesn't hold and allows the top shaft to move some, you may be buying more than just the case.
well i am having a couple issues so i am replacing the tranny case and the motor mount and see if that fixes my constant spur abuse problem.
you could fill the holes with epoxy putty then drill them out and tap them but that would be a pain in the :buttshake:
