i just fitted new upper and lower arms, c hubs steering block etc on my savvy. now my camber seems to be different on each wheel and i think the tracking may be out. how do i adjust this?!!
I assume you had adjustable upper arms, correct? If so, just rotate the turnbuckle to lengthen or shorten the upper arm, depending on which way you want to go. An RPM Camber Gauge is very helpful and easy to use in order to get the camber to the setting you desire and to make all the tires match each other.
