Torn between two servos.
roger25118
Kimberly, WV
The servo you listed should be more than powerful enough. Are you sure you don't have other issues? For instance if your servo saver was too loose it could cause your issue. Or perhaps there is binding in the linkage.
When the wheels are off the ground, they move fine. I'll check the servo saver, but I am sure that it is tight as the manual recommends(4 mm from the bottom).
I have to agree with X, a servo with 200 ozin is more than capable to steer the truck under most all conditions, disconnect the arm and check for something binding and do tighten the saver well.. let us know how it goes..
I cranked down the saver until there was a little gap between each coil. Now the wheels turn on carpet with no problem. I think that I will install the HD spring on the saver at a latter date.
Like the slipper clutch, I lock my steering servo saver down.
Glad you figured it out.
Olds, the Tower TS-170 is a hitec clone(don't remember which one) but at 333 oz. @ 6.0 volts, it doesn't have any problem turning the tires(dirt bones) now that the saver is cranked down. I probably install the HD spring by spring time.
