Motha Trucka
Thursday evenning when I finished running my Savage X I pulled the glow plug and the airfilter and put about 15 drops of after-run oil into the cylinder head, and about 6 drops in the carburator. then I closed everything back up and crancked the engine a few times with my cordless drill. Friday when I went to start my X I had to crank the hell out of it, after a few minutes it started but it would'nt idle very long before it died out. It did this about 3 times before it would idle enough that I could get the truck to move. For about the first 3 or 4 mins it ran TERRIBLE, it would'nt go fast at all, it sputtered, and choked, but gradually it got better, and after about 5 mins it was running fine, acceleration was good, easy to pop wheelies, blus smoke from the exhaust and my temp gun read it was running at 245 degrees, and every time I brought her in to check the temp she idled fine. SOOOO could all the trouble at the beginning have been from too much after-run oil, or could I have a problem somewhere else? If you guys think it's too much after-run oil, could you please tell me how much after-run oil I should put in my truck at the end of the day? And if I might have other problems with the truck could you please tell me what you think?
Thanks Much,
Paul :duh:
Thanks Much,
Paul :duh:
