to be or not to be ?
its DOYLE
MANCHESTER U.K
hi would the shocker/fuel line mod change the impact side off things. with it lowering the sav would it still be able to do bashing/ jumping cheers
DOYLE
I'm not 100% positive but I'm thinking yes you could still bash with that setup but maybe the 10ft jumps may not be a good idea lol other members will have more info for u I'm sure cuz as i said i have never ran that setup!
I am currently running it. I bash all the time I have no problems with it as of yet. Other than being lower and ground clearance for the bottom. You will bottom out with it when you do big air jumps but you can do that even with stock shocks setup. With mine I left the fronts a little higher than the back for clearance but thats it.
IMO doing a mod requires several changes before you like what the truck does. Personally I like the droop a little above the horizntal plain and stiffer, it makes the truck more predictable in response.
