Throttle servo problem
ttuzun
Hi everyone.
The other day I turned my receiver on and realized my throttle servo is moving only 1 way. I tried out the trim theo only thing it did was to allow the servo to move that one way (brake) if its all the way towards the other side.
If i leave it at neutral on the transmitter it would be full speed, if I break, then it breaks. I tried connecting it to a different reciever socket but the same behaviour. The steer servo seems to be working fine. Same as the transmitter.
Is my throttle servo bad? If so, what should I get thank you.
it sounds like a bad servo if the steering works and you plugged it in there and it had the same behavior. definatly a bad servo as for a replacement that depends on your budget if you are looking for something cheap grab a hitec 645mg and use it for your steering and move the sf2 steering servo to your t/b servo . i have had luck with this set up for about 6 gallons now . hope this helps
