Team Epic Brushless Motor Checker
ljrce
Bark River Michigan
Measures KV, RPM, & Tests Sensor Operation
Retail Price $159.99 - Web Price $139.99 US - 1
This 7.4v powered motor dyno allows you to test brushless motors with out the need of hooking up a speed control. Gives you KV, RPM and amp draw at user set voltage input.
There is a mode for testing the function of the sensor to make sure it is functioning correctly.
Runs of standard 7.4V li-Po battery pack, so not big power supply is needed.
Small light and easy to transport to and from the track.
Please note this is a precision piece of electronic equipment and care must be taken in its usage. Hooking the BMC-01 up backwards to the input voltage source will hurt unit and void all warranty.
