Taming an LRP 32 savage missile
francis Labarbara
West Virginia
I have the zr 32 tuned now and it is in fact scary. The truck is a missile. Giving it more than 1/2 throttle is impossible. Even on loose gravel it flips. I am running 47/16 gearing and could go higher but I really don't want more speed. I have taken out some spring preload in the back and that helped. Flipped it so much yesterday I broke a body mount and ripped the body pretty bad. What else can be done to handle the power?
i can't tell if you have the wheelie bar and wheel on the back, if not I suggest getting it, it will help with out of control wheelies
So far, I'm really digging the t-bone rear skid/wheelie bar. I ran it pretty hard yesterday with quite a few endo's and it held up just great. Even with the HPI wheelie bar, the body catches the grass and it folds it up and destroys it. Granted, it's better than nothing, but the tbone one works a lot better at keeping the front end low enough and protecting the rear of the body.
I do have an extra rubber bumper piece to keep my bumper from compressing too much. Totally hack, but it helped with the HPI wheelie bar. I got tired of the little arms that attache to the top of the bumper and bottom of the shock tower breaking frequently.
I'm running the stock 17/47 gearing on mine, and it wheelies also. I'm running trencher x's. When I was just barely done with break in, carb settings still at break in setting, the thing was pulling the front wheels off the ground. This engines just a beast.
I see someone else is running half bodies. Nice to see the torch is carried on. 🙂
Although, looks like you actually use a body mount of some sort on there. That due to tearing up the rear of the body with wheelies and whatnot? If so, you might want to check out t-bonez rear skid/wheelie bar. Seems to be working out really well on my rig.
The new body came and I was going to cut it for the rollbar and the old one was laying there. I then thought about you posting about half bodies. I made a mount that fits to the top of the rollbar. I looked at it again today and thought it looked pretty good so I painted it. I never even cut the new body.
I did it to mine because wheelies messed it up and the roll bar I built would have made me cut the body in half down the middle anyway. I made little mounts on the lower left/right corners to hold the back down.
pist a pic of how u do it or if vids r possible post a vid
Oh, I don't have the rig anymore and pretty sure I don't have pics. I just drilled a couple holes in the sides of the body, then made wire stand offs out of piano wire, drilled a couple holes in the TVP's and mounted them hangers to the chassis, then ran clips through loops I made in the wire. Looked stupid with the body off, but with it on, you didn't even notice them. Besides... wsa running half a body anyway, the whole thing was kind of silly looking, but a half body served the purpose of blocking some grass and whatnot from landing on my air filter and from destroying my front shocks.
EDIT:
Found an old image, but it was pretty small res, so I zoomed in a bit and circled the body mount loops I made:
LST shocks on both ends. Suspension has normal travel. Mounting them required some rearangement of the hardware. I had to find longer screws for the lower ends.They pass threw the shock and both holes in the A arm. On the top I turned the mounts around and reused the screws/nuts. The LST shocks are the same length as the Savage ones.
New clutch shoes in. Back to 47/17 gears from 49/18. Flipped the arms and reattached the shocks. New tires. They made 1 tank on the Octane. Might as well ring them out. I taped them. The cat helped.
I swapped sides and remounted them so they are upside down. This gave me a much better location to drill a hole to mount the shocks. It needs a bath.
Oh, I see. Didn't realize you drilled holes for that. What did that do for you for making it "much better"? Makes it so the shocks can fully extend before the arm is at it's limit? Or did it do that already and this helps make it so the center of the chassis hits the ground before the shocks bottom out?
It allowed me to drill a blind hole into the arm because its much thicker there and the shape of the arm for the original mount is molded in a shape that actually supports the bottom end of the shock. The way I had them before was too weak to hold up and I broke one out.
