STS engine people
votefordurden2008
I found this link somehow on google a few weeks ago and it has came to my attention not many people here know about it. So here it be! Good basic STS info and guidelines.
http://www.stsrc.com.tw/faq.php
Just click up on the .28+ link at the top for some more info.
I have both that one from hop comes with the sts engine but does this sound right ??????Q: What is the factory setting for STS engines?
A: The suggested setting to start with is around;
.12
High Speed needle -- 4 turns out from the end
Low Speed needle -- 4 turns out from the end
Mid Range needle -- Flush with the housing
Idle -- 0.5mm open
.21-.30
LSN -- 4.5 turns out from the end
HSN -- 3 turns out from the end
Idle -- 0.5mm open
Please keep the engine temp. not higher than 120C/248F.
I reset my settings back to factory and it seemed to lean I ran good at allmost 4 turns out mabey thats just me tho
3 turns out from end? is that from the needle completely out or closed? IDK.........
Iam sure its from colsed but who knows anyone????????
Well yesterday i got my sts. We started it up and well it appeared to be running hella rich kind alike a fuel waterfall :). so i checked the site and we counted the screws in. was what they said were factory settings. so we wound em back out from fully closed. so i guess tis from fully closed to back out.
then i busted my pull start
Ah i busted my ps twice and put the roto start on mine and go in at an angle......
Logs: When breaking in an engine especially one that size are you using a heat gun to get the crank case and sleeve up to around 200. Break in w/ PS w/ that much compression will snap any PS. Do this for at least a gallon or close to it. Most folks don't use heat guns and there for goes all problems.
allready busted your ps WOW thats a bummer can u fix it
mine had held up so far
turned out to be faulty plasitc inside pull start the cord ripped through it
hobby guy replaced it
