STS dm28 probs
LogS
Well its not the engine really.. wee had it runnign really sweet...
its the falming one way bearign tis slipping ! anyone had thishapen to an sts engine ?
LMAO....i am having the SAME PROBLEM!!! Ryan sent me another bearing and shaft but he sent the wrong shaft so I replaced just the bearing..still slipped so I took the shaft and got some sandpaper and rubbed it a lot where the bearing sits at and put it back together.......that is after you inspect and make sure NONE of the sand-paper is left on the shaft or in the motor. Help this helps your problem b/c it helped me.
yea i got the pullstart. second one in fact engine had to much comperssion and broke the first ;). but this one just slips so.. putting new plate and shaft and bearing in it today. when it goes thow boy does it GO ! ordered a roto start and the tuned sts pipe yesterday to. so one of these days my truck will run properly..
Truck running ! weeeeeeeeeeeeeeeeeeeeeeeeeeeee
*note* high speed dirt runs do not like breaks applied when sideways ;)
