Defiantspaz
I bought an RB modded STS D30M from STSMicroengines.com this spring. The heat cycle breakin was going great until the backplate came loose during the bliping part of the break in, some blue loctite and all was well again.
I was having some serious issues with the needles of the STS carb moving and leaning out the tune. The needle issue was so bad that it made a full 2 gallon break in almost impossible. I tried green slime, teflon tape and even teflon paste to try and hold the needles from moving but nothing worked. I bullied the STS through the first gallon and a half but constantly have to mess with the needles started to get really boring.
I had a spare HPI K4.6HO from my Hellfire and decided to swap the 9mm STS's carb for the 9mm HPI carb. WOW, problem solved. I have now finished the break in and the engine is just insane. Before the carb switch the tune would be good for a few minutes and during that time the engine was extremely powerfull. Then it would just start to run silly hot because the needles would move. With the HPI carb the tune stays constant.
I have a 3 speed transmission and I am running 15/47 gearing and with the RB STS the truck pulls the front wheels at will. My local track has short straights so alot of top end gearing isn't needed, as it is now I don't top out with this gearing. I am considering moving to a 16/47 so i can keep the wheels on the ground easier. The look on peoples faces when I pull a wheely for the entire front straight is priceless.
I haven't noticed any sacrifice in power from the switch in carbs. When the STS was in tune the performance was the same as with the HPI carb. If anyone of you guys are having a similiar issue with moving STS needles try out either an Axial 9mm or HPI K4.6HO 9mm carb, you won't be disapointed.
When my Savage had the K4.6 powering it with the same exact setup it needed help to pull the front wheels because of how low it is. The difference in power is unbelievable.
