:Mr.confusedk guys have a question i have a sts .30 turbo engine just finished running her in and starting to tune anyway the problem is there is 3 jets witch i had on my last engine
the question is the following
low jet dose low down the high jet dose your top mix i know the other one is for mid but is an air screw of fuel
the reason for asking is with the jets set in factory setting and i turn the high jet in my 1/8 every turn do some runs it runs well but then i want to have better pull off as it smoke like someone just put your hand over the air filter this happens when i pull off
so you getting this lol however i turn the low jet in say a total of 1/2 a turn and she is good then i turn the high jet out by 1/8 turn then run it up and down some more then just as it changes gear it cuts out so i start it back up and turn the high jet out by 1/8 turn so now I'm back to factory setting on the high jet but i want to clean up the mid but when i turn it in less than 1/8 of a turn on idel it start to rev up
so i turn the idel down but no good so i turn the low jet out 1/8 of a turn still no better so then i turn the mid screw out 1/8 of a turn back to factory setting and it slows the rpm down on idel
so can anyone tell me how the hell the 3 jet carb works as there is only 1 inlet were the main is then how the hell dose it feed the low and mid
were on normal 2 stroke carbs you have the main jet at the lowes point then next to that the progretion jet then the idel so you have your 3 jet and 3 holes 1 for each jet
are you you getting all this lol
so any help would be welcome as i can not for the love of me get my head around it
thanks guys
thanks guys
