Stripped hex Savage 3.5
tert
Sweden
Just bought a second hand 3.5 Savage. The previous owner had ditched the 3.5 engine and replaced it with the 4.6. The truck now has soo much power and today I managed to strip on of the hexes (in the rim) so I am thinking about converting to 17mm hexes.
Which is the best conversion kit?
The first link is what I am using, the second if you notice replaces the nut and flange washer and axle with a different nut, both will fit with no mods needed but in truth the first set is just fine for most normal uses...
Just noticed another problem. Mainly all wheel/tire combos for 17mm hexes has atlest a 12mm center bore but the drivcup on my 3.5 Savage is only 8 or 9mm (which is was most 14mm hex rims use for centre bore)
Is it still ok to use a rim with 12mm centre bore?
as long as you use the flanged nut to attach the wheel it will be fine.....
