Form
Hey guys, I've been noticing some slack in the steering assembly on my savy, even though the screws that hold the posts in place are screwed on tight.
I've put up a clip on YouTube to show what I mean: http://www.youtube.com/watch?v=82IXliARNb0
The "problem" is most visible at about 0:16 where I rotate the wheel by hand. In the clip I apply no force to the wheel at all, I just rotate it until there is some resistance. At the steering posts it moves only by about 1.5-2mm but at the wheels this translates to about 10 degrees of free movement. This also makes small trim adjustments pretty much impossible to see when the truck is not running.
Is this normal? What do you think causes this? Do you think the upgrade steering bearings would get rid of this slack?
