will set needles flush and try again today and let you know how i get on?needle settings at factory or close too it? could be fat on the bottom.
what do you mean by fat on the bottom?
cheers for that will spend a bit of time trying to sort it later hard when first start and don't really know how to read the engineLow speed rich
cheers but i bought it 2nd hand when arrived was running but not too great so se all needles flush, managed to get it started but wouldnt tick over at all after a while it did maybe it wa just cold, then i did as tuning link adjusted hsn prob about 1 turn still seemed boggy at bottom end is that too rich or lean?yep. when my 4.6 was new i turned the hsn about a full turn in from flush and then turn in the lsn 1/4 turn in at a time till it would start easily and stay running.
then break in.
then tune using videos or better yet robin's thread.
you gotta get her to run before you can break in & tune.
so do i still need to lean itup with the hsn still? what about the lsn?Too rich if you give it throttle and the motor bogs. Too lean and the motor should rev really quickly but "cackle" like it's not getting enough fuel. Also it should be up to running temp before looking for these signs. When my motor is cold and the tank is full it can take a while to warm up and it will act rich but once it gets hot then it runs better.
