SS brakes and vented CB = problems
noogie
my vented CB and disc brakes are intefering with one another. The disc actually sits in the vent and prevents the CB from spinning. Also, I tried putting the red fiber pads on and the CB does spin at all. Any Ideas?
Jason
Check to see if your screws that hold the disc brakes on have not stripped out the trans case and make sure they are lined up properly. I've seen this problem before and usally this is the case. They like to come loose and then get hooked on the cb and end up stripping out the transmission housing. Good Luck let us know.
I'm at work rite now so I wont beable to post pics till later. I have checked the motor plate and that is not bent. I have also swapped out the tvp's and am still have the same issue.
Jason
what size cb is on it. and is it a low cg tvp? FLM will not work 14/47 in the standard length. lock up just like you say. i was looking for small block options when I found this out
Bank,
I have a 17 tooth CB and stock x tvp's. From what I can see, the disc have alot of play on the brake hub itself. I can move the discs forwards and backward quite freely.
As stated before, even when I put the factory dual fiber discs on I still have issues. The fiber pads rest right up against the CB.
Jason
I had the same problem and it was my plate bent. It was way too difficult to see that with the mill on. The cb in my case tore one of the fiberdisks apart.
