slipper pad problems.
xxxsavage
Hi people, i'm new to this forum and i'm havin problems with my slipper pads.
I'm running hpi.28 + sts .30,titanium 49 spur gear, 18t racing clutchbell
PROBLEM;I keep spitting out slipper pads after only a couple of runs and that is with the nut tightened right up.
Any idea's as to what i may be doing wrong?
ive blown a pad but come to think off it it was the factory one tighten the spur then back it off a 1/4 turn sounds like it might be to tight.
I suggest tighten it up all the way, let it sit for a while. Then loosen as needed. You should also make sure the spur gear is clean. Works for me. Peace.
