Slipper clutch
super nub i drive traxxas
alright i burnt up my slipper clutch so i replaced it. i tightened it up then ran it eventually it just gets loose again(with in a few minutes) any suggestions?
also savage has been down a while, any thing i should do to engine to clean it or anything? its a os .3
I'm trying to get the nut off but when ever i spin nut the metal piece on back of plastic gear spins. how should i hold it? and I'm having trouble finding a wrench to fit that nut did a wrench that came with truck fit it?
I get a screwdriver to hold the plate that spins and use needlenose pliars to get the nut off, I do replace the nut every few times of removing it.
alright the shaft looks fine. but that piece in slipper clutch that kinda looks and feels like sandpaper is worn down and is very smooth. I'm geussing thats the reason its slipping? weird thing is that piece was new and only run a few times. i geuss ill replace that part and tighten it up real good and use locktight this time around
just make sure you drop some after run oil down it the motor and maybe heat the block up w/ a hair dryer
So drop after run oil down where the glow plug goes? Sorry for all the noobie questions. Been off the scene awhile gotta get savage savyness back
hpi 86802 is the part your missin by the sounds of it....if you look in the back of your manual it shows you the breakdown of it all
