romper4444
I'm not sure what you guys are using, if anything at all for a slipper clutch upgrade, but I have been having troubles with stripping out my slipper pad and the littles hexes that are cutout into the spur gear. When it was new it lasted for about two gallons, it was too late before I realized that the slipper was a little too loose from factory, and was slipping probably more than I'd like, but lasted quite a long time considering. I replaced it twice before trimming the inside if the pad and lightly tapping it into the spur hexes. It was self-destructing at the first full throttle take-off with the slipper tightened right down. After trimming it, its been about 5 tanks without a problem, but tightened fully, as i'm scared it will strip again if I allow a little slip. What are some options for a good slipper clutch upgrade, I know company's that make them, but have no idea what works?? I have the Savy x 4.6 RTR. also what the best all around clutch/spur combo, I'm thinking of changing as my wheelies tend to get uncontrollable. i have noticed that in order for my new HPI alum. shoes to properly contact the C.B, it will not ride on the Spur gear properly(hanging off the end a bit) Any idea's or anyone have similiar issues??
Soor for the long thread, kinda crammed a few in there.
