Triple6thug2
- NC
i would like to upgrade my 4 shocks to eight shocks. What all do I need to do this beisides 4 more shock sets? Are the aluminum shock sets worth it?
Integy makes a throttle pivot with bearings.I really like the 4 big bores over the 8 shock setup. However, I find they work better for larger air with a bit stiffer springs and oil in them. The hellfire white springs worked well on mine (still used the short stubby spring). I can't recall the oil I ran though, was too long ago.
Anyone ever run across a throttle pivot with bearings?
Ditching the stock saver thing on the throttle servo and using a spring/slider setup gives you better control over the brakes too. I used a threaded wire for the long throttle wire with a ball end on it. I didn't change the z-bend wire going directly to the carb though.
Or, the cheaper plastic version: http://hpiracing.world/en/part/102365The dual shocks were on the old Savage All the new Savage come stock with big bore plastic shocks one on each side Yes the A720 help well in overall performance of the truck Much better than stock
http://hpiracing.world/en/part/a720
I found a set of plastic BBs on ebay. They should be here in a couple of days. I guess I will get to see the difference soon! Are they a direct replacement for the stock shocks, meaning no modification needed?
i would like to upgrade my 4 shocks to eight shocks. What all do I need to do this besides 4 more shock sets? Are the aluminum shock sets worth it?
