shock oil?
dirtbasher
hi guys,
I'm using big bores wit 30wt shock oil. i find it to soft, wen i push down the truck it gets up too fast. shld it b this way? shld i go for 40 or 50wt shock oil? pls help.
i find 30 wgt perfect for my savage caz i run a lot of un-even surfaces and take lots of jumps.
if your running mostly street & track you can get a heavier wgt like you mentioned, to tune them harder.
thx frddyj,
now I'm using 1 large n 1 small spacer. if i add 1 more large spacer, do i hav to change the shock oil?
all the spacers are doing is giving your springs more rebound, you shouldn't have to change your oil. I run 50wt in all mine.
