servo saver
4x4
england
ive just bought the hpi cam type servo saver and do you have to set it because i notest it had a threaded flat nut thing on the side with the spring?and what is a good setting for it?
tell me if i don't make my self clear (i don't know how to explain it)
thanks 4x4
it should compress the spring so there is approx 4mm gap between the nut and the chassis plate.
you should be able to find some info in the x or ss manuals.
you can adjust the compression to suit your driving.
After you get it set its a good idea to put a drop of blue loctit on the threads to keep it from backing off.
