For Sale Selling my Savage Flux XL
Mvtepixels
I'm selling my Flux XL, it's a fresh rebuild. Asking for 600 euros or 700 dollars. I'd say that more than half of the car is new.
I built it for myself, not to sell, but once it was finished, I thought it was too nice. I'm asking for a bit of money, but a Savage like this one costs way more than a thousand to build...
This is the GTXL-1 version, but with a ton of upgrades.
Some of the upgrades:
  • Machined input and bevel gears
  • The diff cases were modified to hold the 8x16x5 bearings
  • Alza racing center diff kit with an Arrma diff
  • Abcima Servo
  • Castle Creations Mamba Monster X combo with the 2200kv motor
  • TF - 50 radio
  • Tower to tower braces
  • Body shell as a roll cage adapted to it
  • Arrma Backflip LP wheels
  • Stronger shock rod ends
  • Aluminium bushings to reduce shock travel
  • The new V2 hub axles with 17mm hexes
  • Aluminium rear hubs
  • Absima Combat Series 22 Kg servo
List of new parts:
4 X LOWER ARMS
4X UPPER ARMS
REAR SHOCK TOWER
FRONT AND REAR BUMPERS
SKID PLATES
BODY MOUNTS
FRONT GEAR BOX/BULKHEAD SET
EVERY DIRECTION COMPONENTS
4 X NEW SHOCKS
18 X NEW 8x16x5 BEARINGS
2 X LOWER ARM BRACE
2 X STEEL LOWER ARM BRACE
4 X Super HD XL Axle 8x11x57mm
4 X 17mm Hex Hub with 4 X newWheel Nuts
RECEIVER BOX SET
HPI TF-50 TRANSMITTER
2 X Bulkhead Lower Plate 2.5mm
STEERING SERVO MOUNT SET
BATTERY BOX SET (RIGHT/LEFT)
Savage XL Flux GTXL-1 Bodyshell
ARA-1515 Body Roof Support Set
2 X BACKFLIP LP TIRES
AR310429 Spur Gear 50T´
2x SUPER HEAVY DUTY DIFF SHAFT 9x11x34mm
2 x AR310439 Diff Outdrive Steel
2 X SPMXCA503 IC5 CONNECTORS
ALUMINIUM REAR HUBS
EVERY DIFF GASKET
DIFF AND SHOCK OILS - 200 k Front and rear, 500k center, 1325 CST on the shocks
ORINGS
13T ARROWMAX PINION (spring steel)
