So i think all my problems have been sorted now. Almost ;-) i did service my shocks but one or two are leaking. What shocks are you using guys? Are the big bore ones a good upgrade? I'm not doing big,high jumps so they don't need to be mega strong.
There are a few things that can cause leaks, but the most common is the o-rings not sealing. If you use some green slime on the o-rings it should take care of it.
If you choose to buy new shocks you should still buy some, it's great insurance to make sure your shocks don't leak. This can also be used to seal your needle's o-rings on the carb of your engine.
