I noticed that the gearing on the XL is 16/52. Isn't the K5.9 supposed to have more torque than the K4.6? Even with the larger tires this seems a little low. Is the truck a wheelie monster with this gearing? I picked up a cheap 5.9 for my X and was thinking of using the 17/47 gearing (steel spur) that worked well with my stock K4.6 thinking that the 5.9 should have more torque and have no problem moving the truck. I have a 3spd installed and run Maximizer beadlocks with LST II tires and will be adding extended tvp soon. What do you guys think?
I'm also thinking of upgrading to the XL heavy duty dog bones with the wideners (there pretty cheap on EBAY, if I can get the diffs cheap too), but I'm already running 1/2 in offset wheels. I'm a little nervous about the extra load on the bearings. The truck already has the HPI suspension conversion intalled so hopefully broken knuckles won't be a problem. Anyone else running the XL axles with offset wheels? Anyone have any pics of how wide the truck is with this combo and what affect there is on handling?
