Heshup
- Starkville Mississippi
:newb: here! Please help with parts.
My new X SS came this Tuesday. I have not started putting it together yet. I want to get some hop-ups first. What I have come up with so far is this. BTW I have coming this Monday for the radio is Spektrum DX3.0. The 3-speed transmission will be here next week. Money is not the problem, but me not knowing for sure if these parts are for sure the right ones is, and if there is anything else I need to get for them to work or are there better ones.
Hitec HS-5955TG Digital Titanium Servo for the steering. Thought about the JR Z9000T
http://www.smfstore.com/product_info.php?products_id=613
Reverse Module.
http://www.smfstore.com/product_info.php?products_id=52
6x10x3mm Rubber Sealed Bearing for the steering posts. I’ve been told that this is the size.
http://www.smfstore.com/product_info.php?products_id=182
Nova Adjustable 7075 Aluminum 3-piece Clutch.
http://www.smfstore.com/product_info.php?products_id=633
Aftermarket screw kit.
http://www.smfstore.com/product_info.php?products_id=79
Super Hot Shot 2 Standard Glo-Starter.
http://cgi.ebay.com/Hobbico-Hot-Sho...ryZ44028QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Foam inserts for the tires. Not sure what to get. I hear Pro-line but not sure as to the size and should I get the firm ones or in between firm and soft
I am also need this Ofna linkage mod for the throttle/brake but cannot be sure just what I need for parts or where to get them.
Now for the hump-pack. Looking at this.
http://onlybatterypacks.com/showitem.asp?ItemID=10165.17
With this connector.
http://www.onlybatterypacks.com/showitem.asp?ItemID=10776
I understand that this will not fit where it should go but can be put up front by or on the front shock tower. Need to know is their one as good or better that will fit in the right place. Been told with me using 3 servos I don't have much room for this big one.
I need to hit the buy button some time Thursday for what I have above.
After this I will be doing all the suspension and so forth. Then the power plant and drivetrain.
Thanks for any and all help I can get. I intend to take this build as far as I can. Please help me Trick my Truck. I am more interested in seeing just how much of a monster I make out of this, than going out and bashing.
Reverse Module.
