silverback2002
My car has had approx 3 runs, long sessions hi speed oval work. Just recently the pilot bolt must of loosened off and the flywheel started slipping. It ground away the flywheel and now the pilot bolt does up all the way and the flywheel is loose. I will need to buy a new flywheel and pilot bolt
Does anyone know if this happens alot. When I did the pilot bolt up the first time I did it as tight as i could and applied lock tight. What is the best method for tightening this bolt.
