Savage k5.9 Backplate Question
venomtalon
So I pulled my k5.9 engine from my savage to clean and seal her up. I think there might be an issue with the backplate the the one way shaft. Should there be any play with the one way shaft and the backplate? I can wobble it a little and have no idea if that is normal. Sorry for all the questions and thanks for the help!
So I pulled my k5.9 engine from my Savage to clean and seal her up. I think there might be an issue with the backplate the the one way shaft. Should there be any play with the one way shaft and the backplate? I can wobble it a little and have no idea if that is normal. Sorry for all the questions and thanks for the help!
Here is a short video:
well considering there should be a bushing in the backplate it will have play in it like your video is showing....... not too sure if there is a bearing to replace it, possibly a bit of boat grease will serve to tighten it up a bit, but the play is not too much to worry about unless it gets really excessive
Okay, thanks for the feedback.
