Savage flux xs
Peaky Blinder
When in motion there is a whining noise, don’t know if it’s slipper clutch or motor, sounds like motor has the power but not to the wheels like something is slipping, checked all links, all good
Hi, I suggest that you first check that the spring nut is tight before you access the slipper pads (you have to take out the gear box to access them).
If slipper pads need replacement consider making your own leather ones. They last much longer and do not get spoiled when they get wet.:
The slipper spring nut can be accessed from the top of the car, taking out the reciever box.
Removing the gear box in this truck takes some time. I changed to leather slipper pads to avoid having to do this task every time water got into the gearbox.
It depends on your skills and the size of your fingers. Watch this video.
