savage 25 brake issues
nedla
Hi, the brake on my savage does not work using the servo, i can manually activate it. but it seems to need to go far before it works.. pads and disc look ok.. any ideas would be helpful.. Cheers
You can adjust the brakes with the adjustment screw at the end of the brake linkage or if the arm needs more throw, put some fule tubing between the adjustment knob and the servo horn. This will give the brake arm more throw and should give you more braking. Another option you can do is to do a throttle/brake mod. Its a cheap mod that works well. here is a linky for you....
https://www.hpisavageforum.com/forums/showthread.php?t=6977
